I am moving from Libre Office to OnlyOffice and have loved it so far! Very clean UI and things work well. It is slightly slower to load and save files vs Libre but the pros outweigh the cons and I would like to stick with OnlyOffice.
Two features I greatly miss and which have been slowing down my workflow is the ability to press CTRL+SHIFT+V to paste plain text with no formatting. Instead I have to normal CTRL+V and then move my mouse onto the screen and click the drop down menu of the pasted text and change it to plain text. Very slow and a basic feature that should be included.
My second complaint is that I can’t snap a window to a side panel of my screen. For example, with LIbre office I was able to I drag the window to the side of my screen and my computer OS would realize it wanted to make the window 1/2 the screen size so another window like an internet browser can be on the other 1/2. OnlyOffice isn’t able to collapse down to a reasonable size that allows for multitasking and when I need to work on something I have to toggle between windows.
If these two are a feature and I just am doing something wrong, please correct me. Otherwise, these are two wonderful ideas that I have seen in pretty much every other program and software on my computer. I am not sure why OnlyOffice isn’t implementing these.
