I would like to know if it is possible to completely disable the automatic save and the native save button of the ONLYOFFICE editor, so that the saving is controlled exclusively by a “Save” button created in my own application (outside the editor).
In this scenario, which options do I need to disable in the editor configuration, and which event should I use to manually trigger the save from my external application?
Hello @gabrielm97,
Please refer to this thread’s post regarding the question of creating an external save button: Download current document outside the iframe of OnlyOffice - #2 by DmitriiV
As for disabling other saving mechanisms, please refer to this guide: Saving file | ONLYOFFICE.
Note: only force saving and repeated force saving can be disabled (which are responsible for current document state saving) — final saving will still occur automatically when all users disconnect from the editing session.
