Toolbar customization
1.Is it possible for me to modify the name of the plugin tab in the toolbar?
2.Hide buttons from the toolbar menu. For example, we need to display a blank page alone in the insert toolbar.
Hello @subbu, presently there is no way to implement the above-mentioned customization. You can check out all the available customization options by following the link below:
https://api.onlyoffice.com/docs/docs-api/usage-api/config/editor/customization/#layout
