Need dedicated support? Click here
Click here
Thumbnail for gnome/mate
To generate document thumbnails in the file managers Gnome or Mate (Nautilus and Caja, respectively), special helpers are used - thumbnailers. The existing thumbnailer generates thumbnails for OpenDocument ods/odt files, but cannot create them for OpenXML docx/xlsx files due to the lack of graphic thumbnails inside them.
The essence of my request:
  1. generate thumbnails in the documents being processed and they will be processed normally by the existing thumbnailer.
  2. alternative option - make it possible to launch the office in headless mode with the generation of a graphical representation of the first page of the document and then you can use onlyoffice as a separate thumbnailer.
Additional details can be found here https://askubuntu.com/questions/1368910/how-to-create-custom-thumbnailers-for-nautilus-nemo-and-caja
Hello @alef
We are working on this feature already. I have collected your request and I will update this thread when we have something to share.
