According to the official example, the data in the selected image can be replaced, but if I perform the second replacement, the result is completely different from the first one.
This is the first time
This is the second time
Hello @bashfuldeng
Please correct me if I’m misunderstanding the usage scenario, it goes like this:
- You select an existing image in the document;
- To the selected image you apply method via plugin to replace the image;
- Then selecting the newly replaced image and executing method one more time.
Is that correct?
Yes, there’s no problem with your understanding.
Thanks for confirmation.
We are checking the situation. I will update this thread once any results come up.
