The spacing between numbers in OnlyOffice collaboration space is too large
1. Do you want to:
  • Report a bug
2. Description of the bug:
  • The spacing between numbers in OnlyOffice collaboration space is too large, making it difficult to read and align the numbers properly.
3. Steps to reproduce:
  1. Launch OnlyOffice DocSpace on a CentOS 7 Docker server.
  2. Create a new document and insert numbers (e.g., in a table).
  3. Observe that the numbers are spaced too far apart in comparison to the standard font spacing.
4. DocSpace version:
  • 3.0.4.1
5. Type of installation:
6. OS:
  • CentOS 7
7. Browser version:
  • Chrome 89
8. Additional information:
  • Proxy settings: No proxy used.
  • No configuration changes made.
  • Server logs do not show any relevant errors related to this issue.
9. Attachments:
  • Screenshot showing the issue with the numbers’ spacing.
Does the issue occur with all documents?
Please note that the version you are using is outdated. Kindly update to the latest version (Releases · ONLYOFFICE/DocSpace · GitHub) and check whether the issue persists.
If the problem remains, please provide the original document for further investigation.
I performed some tests, and the number input issue could not be reproduced in the latest version. The issue may also be related to specific fonts used in the document.
@DmitriiV
Thank you for your reply. The attached file is the original document. You will encounter this issue on the third page when opening the Word document.
test.docx (68.3 KB)
The problem didn’t reproduce on our side, no additional fonts installed on the server.
Did you install any additional fonts/removed any of the existing ones?
Also, please provide a screenshot of docker ps command’s full output
