The document security token is not formed correctly
Hello, I encountered some problems when trying to integrate onlyoffice in vue.
First I introduced a well-built document parsing api in public/index.html:
<script type='text/javascript' src='http://43.138.121.194:8701/web-apps/apps/api/documents/api.js'></script>
Then I define a vue component:
<!-- only office 编辑器-->
<template>
    <div id='onlyOfficePreview'></div>
</template>
<script>
export default {
    props: {
        option: {
            type: Object,
            default: () => {
                return {}
    data() {
        return {
            doctype: '',
            docEditor: null,
    beforeDestroy() {
        if (this.docEditor !== null) {
            this.docEditor.destroyEditor();
            this.docEditor = null;
    watch: {
        option: {
            handler: function (n) {
                this.setEditor(n)
                this.doctype = this.getFileType(n.fileType)
            deep: true,
    mounted() {
        if (this.option.url) {
            this.setEditor(this.option)
    methods: {
        async setEditor(option) {
            this.doctype = this.getFileType(option.fileType)
            //配置项
            let config = {
                document: {
                    //后缀
                    fileType: option.fileType,
                    key: option.key || '',
                    title: option.title,
                    permissions: {
                        //是否可以编辑: 只能查看,传false
                        edit: option.isEdit,
                        print: option.isPrint,
                        download: false,
                        //是否可以填写表格,如果将mode参数设置为edit,则填写表单仅对文档编辑器可用。 默认值与edit或review参数的值一致。
                        // "fillForms": true,
                        //跟踪变化
                        // "review": true
                    url: option.url,
                documentType: this.doctype,
                editorConfig: {
                    //"编辑word后保存时回调的地址,这个api需要自己写了,将编辑后的文件通过这个api保存到自己想要的位置
                    callbackUrl: option.editUrl,
                    //语言设置
                    lang: option.lang,
                    //定制
                    customization: {
                        //是否自动保存
                        autosave: false,
                        chat: false,
                        comments: false,
                        help: false,
                        // "hideRightMenu": false,//定义在第一次加载时是显示还是隐藏右侧菜单。 默认值为false
                        //是否显示插件
                        plugins: false,
                    user: {
                    mode: option.model ? option.model : 'edit',
                width: '100%',
                height: '100%',
                token: option.token || ''
            // eslint-disable-next-line no-undef,no-unused-vars
            this.docEditor = new DocsAPI.DocEditor('onlyOfficePreview', config)
        getFileType(fileType) {
            let docType = ''
            let fileTypesDoc = [
                'doc', 'docm', 'docx', 'dot', 'dotm', 'dotx', 'epub', 'fodt', 'htm', 'html', 'mht', 'odt', 'ott', 'pdf', 'rtf', 'txt', 'djvu', 'xps',
            let fileTypesCsv = [
                'csv', 'fods', 'ods', 'ots', 'xls', 'xlsm', 'xlsx', 'xlt', 'xltm', 'xltx',
            let fileTypesPPt = [
                'fodp', 'odp', 'otp', 'pot', 'potm', 'potx', 'pps', 'ppsm', 'ppsx', 'ppt', 'pptm', 'pptx',
            if (fileTypesDoc.includes(fileType)) {
                docType = 'text'
            if (fileTypesCsv.includes(fileType)) {
                docType = 'spreadsheet'
            if (fileTypesPPt.includes(fileType)) {
                docType = 'presentation'
            return docType
</script>
Finally, I call the component in app.js:
<template>
    <div id="app">
        <div class='qualityManual-container'>
            <div style="margin-bottom: 10px">
                <el-button style='width: 120px;' type='primary' @click='previewPdf'>预览PDF文档</el-button>
                <el-button style='width: 120px;' type='primary' @click='previewExcel'>预览Excel文档</el-button>
                <el-button style='width: 120px;' type='primary' @click='close'>关闭</el-button>
            </div>
            <div v-if='show' class='qualityManual-container-office'>
                <only-office-preview :option='option'/>
            </div>
        </div>
    </div>
</template>
<script>
import onlyOfficePreview from '@/components/only-office/preview.vue'
export default {
    components: {
        onlyOfficePreview
    data() {
        return {
            //参考vabOnlyOffice组件参数配置
            option: {
                url: '',
                isEdit: '',
                fileType: '',
                title: '',
                lang: '',
                isPrint: '',
                user: {id: null, name: ''}
            show: false,
    methods: {
        // 预览PDF
        previewPdf() {
            this.show = true
            this.option.isEdit = false
            this.option.lang = 'zh-CN'
            this.option.url = 'http://43.138.121.194:8701/onlyoffice_file/test1.pdf'
            this.option.title = 'test1'
            this.option.fileType = 'pdf'
            this.option.isPrint = false
            this.option.user = {id: 12, name: '测试'}
        // 预览Excel
        previewExcel() {
            this.show = true
            this.option.url = 'http://43.138.121.194:8701/onlyoffice_file/test.xlsx'
            this.option.title = 'test'
            this.option.fileType = 'xlsx'
        close() {
            this.show = false
</script>
<style>
/*#app {*/
/*  font-family: Avenir, Helvetica, Arial, sans-serif;*/
/*  -webkit-font-smoothing: antialiased;*/
/*  -moz-osx-font-smoothing: grayscale;*/
/*  text-align: center;*/
/*  color: #2c3e50;*/
/*  margin-top: 60px;*/
html, body {
    height: 100%;
#app {
    text-align: center;
    color: #2c3e50;
    height: 100%;
.qualityManual-container {
    padding: 0 !important;
    height: 100%;
.qualityManual-container-office {
    width: 100%;
    height: calc(100% - 55px);
</style>
But when I ran it, an error occurred: the document security token was not formed correctly. Please contact your file server administrator:
I hope to get some help, thank you.
Hello @caiwei
Please let us know your version of Document server and installation type (point us to the guide which you used).
As for the issue in general, first of all please check out if this link is available via browser from your PC (paste it to a browser):http://43.138.121.194:8701/web-apps/apps/api/documents/api.js
Please check out that your JWT secret\header match on both sides. On Document server side it’s located in the local.json config file. Also probably we have to take a look at Document server logs. Please reproduce the situation and provide us with them. They’re located here:
docker: /app/onlyoffice/DocumentServer/logs/documentserver/
deb\rpm: /var/log/onlyoffice/documentserver/
Windows: Program Files\ONLYOFFICE\DocumentServer\log
Thank you for your reply. After I reduced the version, there will be no such problem. Thank you very much
Hello @caiwei
What do you mean by ‘reduced the version’? Have you deployed older version of Document server? If so, the issue probably isn’t solved, because we always recommend to use the latest versions of our products.
Please provide us with details of steps you performed to solve the issue.
I used version 7.2 before, but after I changed it to version 7.1, this problem did not occur. Thank you very much
This isn’t a good step. We always recommend to use the latest version (each new version contains bug fixes and new features). Please try to update your Document server to v.7.3.3 and check out if the situation changes.
