The document security token is not correctly formed with framework vue js
i’ve installed onlyoffice document in private server, but the display keep showing “The document security token is not correctly formed.” is there any tutor for the integration with the framework especially vue js?
i thought the display will be changed after i add the token but web keep appearing this display
Hello @renataa
This error means that when initializing editors you are either not providing or providing incorrect JWT Token to authorize the request. You can find more information about token here:
Starting from version 7.2 JWT is enabled by default so you must provide it in order to initialize editing session. If you are not planning to use JWT in your integration, you can disable it, please see how to do it here:
Please note that we do not recommend disabling JWT due to security reasons.
By the way, you can use our Vue component to integrate Document Server with your application too:
this is main file
<template>
    <div class='qualityManual-container'>
        <div v-if='show' class='qualityManual-container-office'>
            <onlyoffice :option='option' />
        </div>
    </div>
</template>
<script>
import onlyoffice from '@/views/file/component/add-file/onlyoffice';
export default {
    components: {
        onlyoffice,
    data() {
        return {
            option: {
                url: '',
                isEdit: true,
                key: 'SECRET_KEY',
                fileType: '',
                title: '',
                lang: 'eng',
                isPrint: true,
                user: {
                token: 'SECRET_TOKEN'
            show: false,
            list: [
                { name: 'My Document 1.doc', id: 1, title: 'My Document 1.doc', url: 'https://example.com/url-to-example-document.doc', fileType: 'doc' },
                { name: 'My Document 2.xls', id: 2, title: 'My Document 2.xls', url: 'https://example.com/url-to-example-document.xls', fileType: 'xls' },
                { name: 'My Document 3.xls', id: 3, title: 'My Document 3.xls', url: 'https://example.com/url-to-example-document.xls', fileType: 'xls' },
                { name: 'My Document 4.doc', id: 4, title: 'My Document 4.doc', url: 'https://example.com/url-to-example-document.doc', fileType: 'doc' },
                { name: 'My Document 5.txt', id: 5, title: 'My Document 5.txt', url: 'https://example.com/url-to-example-document.txt', fileType: 'txt' },
    created() {
        this.loadOnlyOffice(this.$route.query.id);
    methods: {
        loadOnlyOffice(val) {
            let optionTemp = {};
            for (let i = 0; i < this.list.length; i++) {
                if (this.list[i].id == val) {
                    optionTemp = this.list[i];
                    break;
            this.option.name = optionTemp.name;
            this.option.id = optionTemp.id;
            this.option.title = optionTemp.title;
            this.option.url = optionTemp.url;
            this.option.fileType = optionTemp.fileType;
            console.log(this.option);
            this.show = true;
</script>
<style>
.qualityManual-container {
    padding: 0 !important;
    height: 100%;
.qualityManual-container-office {
    width: 100%;
    height: 100%;
</style>
this is onlyoffice file
<template>
  <div id='onlyoffice'></div>
</template>
<script>
export default {
  props: {
    option: {
      type: Object,
      default: () => {
        return {};
  data() {
    return {
      doctype: '',
      docEditor: null,
  beforeDestroy() {
    if (this.docEditor !== null) {
      this.docEditor.destroyEditor();
      this.docEditor = null;
  watch: {
    option: {
      handler(n) {
        this.setEditor(n);
        this.doctype = this.getFileType(n.fileType);
      deep: true,
  mounted() {
    if (this.option.url) {
      this.setEditor(this.option);
  methods: {
    async setEditor(option) {
      this.doctype = this.getFileType(option.fileType);
      let config = {
        document: {
          fileType: option.fileType,
          key: option.key || '',
          title: option.title,
          permissions: {
            edit: option.isEdit,
            print: option.isPrint,
            download: false,
            fillForms: true,
            review: true,
          url: option.url,
        documentType: this.doctype,
        editorConfig: {
          callbackUrl: option.editUrl,
          lang: option.lang,
          customization: {
            autosave: false,
            chat: false,
            comments: false,
            help: false,
            plugins: false,
          user: {
          mode: option.model ? option.model : 'edit',
        width: '100%',
        height: '100%',
        token: option.token || '',
      this.docEditor = new DocsAPI.DocEditor('onlyoffice', config);
    getFileType(fileType) {
      let docType = '';
      const fileTypesDoc = [
        'doc', 'docm', 'docx', 'dot', 'dotm', 'dotx', 'epub', 'fodt', 'htm', 'html', 'mht', 'odt', 'ott', 'pdf', 'rtf', 'txt', 'djvu', 'xps',
      const fileTypesCsv = [
        'csv', 'fods', 'ods', 'ots', 'xls', 'xlsm', 'xlsx', 'xlt', 'xltm', 'xltx',
      const fileTypesPPt = [
        'fodp', 'odp', 'otp', 'pot', 'potm', 'potx', 'pps', 'ppsm', 'ppsx', 'ppt', 'pptm', 'pptx',
      if (fileTypesDoc.includes(fileType)) {
        docType = 'text';
      if (fileTypesCsv.includes(fileType)) {
        docType = 'spreadsheet';
      if (fileTypesPPt.includes(fileType)) {
        docType = 'presentation';
      return docType;
</script>
is there any problem with my vue code?
and for the ‘url’ it must path from the server right? if the path is not from the server then the code doesn’t run?
What kind of data is returned as option.token? It must follow the structure of JWT Token according to the documentation. If you are providing random string, then it explains the error.
Please see description of document.url parameter here:
As you can see it must be accessible for Document Server absolute URL to the file.
