The document not be saved ONLYOFFICE
I’ve been trying to get OnlyOffice to work over HTTPS for a while now, but I got stuck on the “document cannot be saved” message and couldn’t find a solution for this. I tried:
disabling token requests for incoming, outgoing messages and the browser in local.json,
setting rejectUnauthorized to false, and allowPrivate/MetaIpAddress to true by default.json,
opening all ports used by OnlyOffice.
Nothing helped.
It only works until the certificate is installed over the HTTP protocol. After installation, it seems to work correctly when I connect to it either through a domain or a private ip address, or at least the welcome screen appears. The sample documents don’t work.
Hello @Kakhmetov
Please specify guide that you used to install DocSpace and enable HTTPS.
in the plan, I installed the manual according to the instructions
Please share a link to the guide for reference. It is not quite clear what steps did you perform to enable HTTPS for your DocSpace instance.
