The document could not be opened
When I try to edit a doc via nextcloud I get error like “content lock” error
My environement :
docker image
nextcloud:22
onlyoffice/documentserver:latest
reverse proxy
from https:// nextcloud.XXXXXX.fr to http:// localhost:8085
from https:// onlyoffice.XXXXXX.fr to http:// localhost:8666
I use a wildcard SSL certificate
when I try to edit a doc from the onlyoffice/example page I get : “The document could not be saved. Please check connection settings or contact your administrator.”
with the error log Error:
Error: Error response: statusCode:404; headers:{"date":"Sun, 06 Feb 2022 23:18:54 GMT","server":"nginx/1.18.0 (Ubuntu)","content-type":"text/html; charset=utf-8","vary":"Accept-Encoding","x-powered-by":"Express","content-security-policy":"default-src 'none'","x-content-type-options":"nosniff","content-encoding":"gzip","keep-alive":"timeout=5, max=100","connection":"Keep-Alive","transfer-encoding":"chunked"}; [2022-02-06T23:18:54.642] [ERROR] nodeJS - error downloadFile:url=http://onlyoffice.xxxx.fr/download?fileName=new.pptx&useraddress=xx.xx.xxx.xx__10.0.3.1;attempt=3;code:null;connect:null;(id=xx.xx.xx.xx__10.0.3.1http___onlyoffice.xxx.fr_files_xx.xx.xx.xxx__10.0.3.1_new.pptx1644174597022)
Sorry for my poor english.
Hello @teauma
Is this issue related to integrated example only? or is there the same issue with Nextcloud integration?
Please go to ONLYOFFICE connector page > click Save button and show us the output result. After that provide us with whole Document server logs folder.
