Hello, I using your conversion API to convert docx file into pdf. In general it work great but I’ve got a document that contains “Header” made with table. So when I get pdf from that document the text from that table overlaps. I tried different options from ONLYOFFICE Api Documentation - Conversion API such as documentLayout and documentRenderer etc but nothing helped. I suggest this is a bug could you please this document. Attach google disk link with doc below
ISV4.12.docx - Google Docs
Hi @dgubanov
Please provide a screenshot of how it appears on your end)
Hi @dgubanov
We have created a bug report for the issue you encountered
Implementation of the following feature is needed: Wrapping tables around floating objects.
Thank you for the file!
