Technical Support
Hey,
I have been using only office for a while now, but I cannot use it at the moment due to this following error preventing the application from starting.
desktopeditors         ✔
(DesktopEditors:238918): GLib-CRITICAL **: 11:48:22.006: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
zsh: segmentation fault (core dumped)  desktopeditors
Application version:
local/onlyoffice-desktopeditors 8.3.0-1
    Open-source office suite that combines text, spreadsheet and presentation editors.
I am running 5.15.177-1-MANJARO
Thanks for any help.
The same problem here. Fresh Manjaro (Minimal) installed at the end of January - Linux 6.12.12-2-MANJARO.
Hello @quantum_c, @kepmic
We are aware of this issue. It will be fixed in upcoming hotfix 8.3.1.
Sorry for the inconvenience.
Hello Constantine,
Thanks for the update/communication. Will look to the hotfix. Just wanted to check if it was my personal install issue.
Best.
