Tab does not calc
I have a rather extensive table with many formulas approx. 15 000.
Since about 2 weeks the table does not calculate the formulas anymore.
For old formulas, results that were calculated before the problem occurred are still displayed.
Few formulas are displayed as an empty field.
Even the prompt “Calculate table” or “Calculate current sheet” does not change this.
The behavior is the same on different PCs with local installation, on different Android devices and in the web application.
Is there a setting that prevents the calculation?
Could it be due to an error in the document?
Is the product at its limit?
VG
Lo
Hey @lojo :handshake:
It seems like you’re facing some issues with your table not calculating formulas anymore. That sounds quite challenging, especially with a table as extensive as yours.
Would it be possible for you to share the problematic file with us for testing?
It might be difficult for us to replicate the issue without the actual file. If there are any sensitive details in the document, please feel free to remove them before sharing.
You can send it directly to PM —I’d be grateful for your help!
Thank you!
Thank you, we are analyzing the file you sent.
As soon as we have reviewed this case, I will get back to you!
@lojo :hugs:
We’ve logged a bug for the issue you mentioned, and our team is on it.
Really appreciate your help in making our editors better.
Hello @lojo
I’m pleased to inform you that a new version has been released. Please check to see if your issue has been addressed with this update.
You can view the details of the changes in the latest version (8.2.2) here.
