Report a bug.
OS version: Win 10 Pro 22H2
App version: 7.3.3.50 (x64 exe)
Using Document writer function.
Hi Team,
Using small “Callout” shapes with text like “#1” to annotate an image pasted into the document.
Rather than creating a new callout, I copy the previous one, paste it back, and move into position, and amend the internal text. This is faster, keeps them consistent, and less effort
Each time the aforementioned shape is pasted, a carriage return is inserted into the document. As the image has focus, the CR appears before the image appearing as a blank line.
Of course, afterwards, I just clean up by deleting all these unneeded lines. It is just an effect that I have not seen with other Word processors. And certainly not a “show-stopper”.
Hello @DavidRGreen
Could you please make a small video demonstration of the issue that you are facing for better visual understanding?
Additionally, if possible please prove a test file where this issue can be reproduced for analysis or provide a step-by-step scenario on how to reproduce it.
You can upload the references on any cloud storage and share a link to it.
Hi Constantine,
I don’t have any software for doing screen recording. The built-in software, some X-Box utility doesn’t want to work, so I’ll use a more elementary approach, 3 screen-shots.
The document I was working on quite large, 10MB of 38 pages, so I created a small single page to simulate.
I also turned on display hidden characters to better illustrate.
I was going to include 3 separate images, but when I tapped the reply button, the forum says, “New users only allowed 1 embedded image”
So I had to stitch them into a single image;
Top is initial position,
Middle is Select and copy using Ctrl-C,
Bottom is paste using Ctrl-V.
Note the new CR that appears between the heading and the image.
… that’s it.
I don’t seem to be able to attach the sample document. This forum only allows the inclusion of image data.
But the sample is only Heading 1, Screen-shot, then Heading 4.
I hope this helps illustrate this “minor” issue.
Thanks for the explanation, I was able to reproduce the issue.
We are checking it, I will update the thread once we get any results.
I want to inform you that we have registered this issue in our internal tracker and started working on it.
Thank you for reporting.
