Hi! Is there any way to prevent macro execution by click or any other action? Like, you’re having a macro that’s executing pretty long and you want to stop it when you tab ‘Esc’ or whatever.
Maybe there’s an “api.asc_(methodName)” method that’s doing that? Thanks in advance!
Thank you for bringing up this scenario. As far as I know, this functionality is not currently implemented, and there’s no such method available in the API at this time.
That said, we really appreciate your suggestion! We’ll log this as a feature request based on your described use case. Once the feature is implemented, I’ll make sure to notify you.
For now, there’s no timeline for its implementation, as is often the case with new proposals.
If you or your friends/colleagues have similar needs, please feel free to share your feedback and add comments to this topic.
Thank you for your suggestion! We’ve reviewed your idea about stopping macro execution with a key like “Esc” or similar. While it’s a great concept, currently, there’s no direct method in the API to achieve this.
We’ve created a suggestion to consider adding such functionality in the future, but at this time, it’s not planned for implementation in the near term. We appreciate your input, and if there are any updates, we’ll be sure to let you know!
