Start from where you left off..Excel
Hello there, just started using Only Office on fedora 40, but will transfer to LDME this weekend.
Its a very quick question but working with large spreadsheets its handy to start again from where you were last working, it maybe 200/300 hundred rows down but when opening Only Office spreadsheet it starts at row 1 each time.
Checked through options and preferences but couldn’t see anything obvious as OO is so similar to Excel I would guess its there somewhere to switch on, not an easy topic to Google successfully either.
Thanks for any pointers.
Quick update, most of the sheets are existing in xlx format, when creating a new sheet with OO the problem becomes less obvious, not all the time but for the most part new sheets open where you left off.
whilst writing, is there any way to increase the the menu bar size, for some reason its really small very hard to select options - thanks
There is the following option:
Setting > Open File > In Its own tab
Desktop editors saves the last location of the document on the screen
As for your menu question, please clarify, what menu are you referring to?
