Do you want to: Report a bug / Ask a how-to question
Community Server/Control Panel version: Latest
Type of installation of Workspace (docker, deb/rpm, exe) : docker-compose
OS: Amazon Linux 2
I have installed onlyoffice on a development server using docker-compose. The server is under a NAT. When I tried to integrate SSO using onelogin I faced few issues.
IdP metadata file is not getting uploaded (URL and file both don’t work). Gives a 504 error.
IdP certificates and SP certificates are not uploading. Stucks in please wait and then closes.
Can’t download onlyoffice SP metadata file. It gives a timeout error
Following logs can be found in the logs folder
Control panel log
2023-10-19 05:13:22 - error: http://onlyoffice-community-server/sso/loadmetadata Unexpected token < in JSON at position 0
Community server logs
web.sso log
{“message”:“getPortalSsoConfigUrl: https://hsuite.cyou/ssologin.ashx?config=saml",“level”:"debug”}
{“error”:{“message”:“request to https://hsuite.cyou/ssologin.ashx?config=saml failed, reason: connect EHOSTUNREACH 124.43.131.134:443”,“type”:“system”,“errno”:“EHOSTUNREACH”,“code”:“EHOSTUNREACH”},“level”:“error”,“message”:“uncaughtException: request to https://hsuite.cyou/ssologin.ashx?config=saml failed, reason: connect EHOSTUNREACH 124.43.131.134:443\nFetchError: request to https://hsuite.cyou/ssologin.ashx?config=saml failed, reason: connect EHOSTUNREACH 124.43.131.134:443\n at ClientRequest. (/var/www/onlyoffice/Services/ASC.SsoAuth/node_modules/node-fetch/lib/index.js:1461:11)\n at ClientRequest.emit (node:events:513:28)\n at TLSSocket.socketErrorListener (node:_http_client:502:9)\n at TLSSocket.emit (node:events:513:28)\n at emitErrorNT (node:internal/streams/destroy:151:8)\n at emitErrorCloseNT (node:internal/streams/destroy:116:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)”
web.socketio log
2023-10-19 10:42:05 - error: https://hsuite.cyou/api/2.0/batch.jsonconnect EHOSTUNREACH 124.43.131.134:443
2023-10-19 10:42:52 - info: POST /controller/counters/sendUnreadUsers 200 4.855 ms - -
nginx logs
2023/10/19 10:43:22 [error] 2323#2323: *44699 upstream timed out (110: Unknown error) while reading response header from upstream, client: 112.134.243.176, server: , request: “POST /controlpanel/sso/loadmetadata HTTP/2.0”, upstream: “http://172.24.0.6:80/controlpanel/sso/loadmetadata”, host: “hsuite.cyou”, referrer: “https://hsuite.cyou/controlpanel/sso”
2023/10/19 10:43:22 [error] 2323#2323: *46070 upstream timed out (110: Unknown error) while reading response header from upstream, client: 172.24.0.6, server: _, request: “POST /sso/loadmetadata HTTP/1.1”, upstream: “https://127.0.0.1:443/sso/loadmetadata”, host: “onlyoffice-community-server”
How can I overcome this issues?
