Do you want to: Report a bug
Step 1: Install DocSpace using the script provided in the documentation (tested both community and enterprise editions)
Step 2: Do configuration on WebUI
Step 3: Run ssl script (tested on both community and enterprise edition)
DocSpace version: 2.5.1.1
Type of installation of the DocSpace (docker, deb/rpm, exe, please point us to the installation guide that you used as well): Docker
OS: Ubuntu 22.04
Browser version: Firefox but not important for this issue
Additional information: After sucesfully installing DocSpace Community or Enterprise and doing the WebUI configuration and custom domain setup i ran the ssl script mentioned in the docs Switching your DocSpace to HTTPS when installing using Docker - ONLYOFFICE and i got the error below:
Recreating onlyoffice-proxy ...
ERROR: for onlyoffice-proxy 'ContainerConfig'
Traceback (most recent call last):
File "/usr/bin/docker-compose", line 33, in <module>
sys.exit(load_entry_point('docker-compose==1.29.2', 'console_scripts', 'docker-compose')())
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 203, in perform_command
handler(command, command_options)
File "/usr/lib/python3/dist-packages/compose/metrics/decorator.py", line 18, in wrapper
result = fn(*args, **kwargs)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1186, in up
to_attach = up(False)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1166, in up
return self.project.up(
File "/usr/lib/python3/dist-packages/compose/project.py", line 697, in up
results, errors = parallel.parallel_execute(
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 108, in parallel_execute
raise error_to_reraise
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 206, in producer
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/project.py", line 679, in do
return service.execute_convergence_plan(
File "/usr/lib/python3/dist-packages/compose/service.py", line 579, in execute_convergence_plan
return self._execute_convergence_recreate(
File "/usr/lib/python3/dist-packages/compose/service.py", line 499, in _execute_convergence_recreate
containers, errors = parallel_execute(
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/service.py", line 494, in recreate
return self.recreate_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 612, in recreate_container
new_container = self.create_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 330, in create_container
container_options = self._get_container_create_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 921, in _get_container_create_options
container_options, override_options = self._build_container_volume_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 960, in _build_container_volume_options
binds, affinity = merge_volume_bindings(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1548, in merge_volume_bindings
old_volumes, old_mounts = get_container_data_volumes(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1579, in get_container_data_volumes
container.image_config['ContainerConfig'].get('Volumes') or {}
KeyError: 'ContainerConfig'
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
No modifications were done prior or post installation. Only the script as per documentation were used.
