Square and curly brackets shortcuts are not working
Hi,
I hope this is the right forum.
I would like to ask why the shortcuts of square and curly braces are not working in onlyoffice.
If I press the shortcuts nothing happens:
The shortcut for square braces is: alt + [
The shortcut for curly braces is: alt + shift + [
Onlyoffice is installed on a Macbook Pro (MacOS 10.15.7) with Italian keyboard.
Thank you.
Hello @Anna
Where do you use these shortcuts? I have checked MS and Libre. They don’t support these hotkeys.
Could you please reproduce the situation in our editor and other one and make a videofile? Also let us know exact version of other editor.
Hi Alexandre,
thank you for your reply.
Here is the video:
The other editor is OpenOffice 4.1.10
Thank you for the videofile, we are checking the situation.
Hello @Anna
We have added your request to bug 59171. We are working on it.
Probably there’s workaround solution while we are fixing it. Please try to use this option:
Hi Alexandre,
I’m sorry for the delay, I didn’t get the notification.
That box was already checked, so I uncheked it and tried again, but the braces still do not work.
Thank you anyway. I’ll just keep on copying and pasting for now.
Please accept our apologies for this situation. We can’t provide you with workaround solution, but we are working on mentioned bug already.
I’ll update this thread when we have something to share.
No problem, Alexandre. Thank you.
Hello @Anna
We have released Document server v.7.5. This version contains a fix for described earlier situation in this thread.
