Suggest a feature for Spreadsheets
I’d like to be able to double click (the black cross appearing on the bottom-right corner) a cell containing a formula and it will drag down (extend down / expand down) the formula until it reaches the last row with values, as MS Excels does. Otherwise it has to be dragged down manually, which can take its time on files containing >50k rows.
N/A
OS version: Windows10
App version: 7.0.0.127
Downloaded from: ONLYOFFICE website / Other (specify): ONLYOFFICE (updated from existing version)
