Spreadsheet - Incomplete Header/Footer
Greetings from a new user.
I have been trying to create a one-pager spreadsheet with header and footer.
Whatever margin/scaling settings I use, the Left & Right extremities of my header and footer are cut off by a few pixels.
It looks ok in setup, but incomplete in print/pdf export as you can see in this image:
Anyone any tip?
Thank you
Didn’t test, as variant page is formatted as Letter and default printer driver page size is A4. Or like. I guess here is no automatic conversion from one to another.
Hi,
Good thinking, but unfortunately that’s not the issue.
Both document and printer settings are on A4
Have no more ideas, sorry. Still didn’t test that in my environment. OnlyOffice in my case is only to test the water, not the main app.
Thanks for trying
hi @ChacsamBe
Well, it’s not the most ideal idea, but you can add two spaces before the heading paragraph.
I apologize for it. :slightly_smiling_face:
We are checking the situation.
I will notify you as soon as there is a result.
Thank you for bringing it to our attention!
Hi @Nikolas,
Thanks for the follow up and the creative tip :slight_smile: .
The two spaces could be an ok workaround as far as the left-aligned header is concerned.
It doesn’t help on the right aligned part of my header (neither top, nor bottom).
FYI issue is the same when I try to put a picture (eg logo) in the header
:eyes:
I’ll add it to the problem description! :handshake:
@ChacsamBe
As it turns out, we discovered this issue earlier…
The fix will be included in the next release (7.5.1). :handshake:
As usual, I can’t provide an exact release date, but I can tell you that it’s planned within a month.
Thanks for the swift follow up!
Happy to confirm that the issue is solved in 7.5.1.23 I have updated today
