Hi
In some case (I don’t understand which ones), the double click to change the height of a line doesn’t work:
The file :
bug line heigh.xlsx (7.9 KB)
Is it a bug ?
Thanks !
Hi
The file :
Is it a bug ?
Thanks !
Hello @arcqus
We are checking the situation. I will update this thread when we have something to share.
And at least, even after installing 7.4.1, I still have the issue
Hello @arcqus
The described behavior is expected if you manually changed the line height before running the test. I believe there’s no issue.
Ok, so this is a feature
I don’t really like it (because even if in the past I changed the height of the line, why couldn’t I resize it via the most efficient way (ei double click the line) later ?).
But I’m no UI expert.
Let’s keep this thread open. If there’re new requests on this behavior, we will discuss it internally one more time. This is expected behavior for now and I’m not sure that there’s point to change it.
Hi Alexandre
On the video above, you can see what is, according to me, not the right behaviour.
In a new spreadsheet:
hey @arcqus
I’ll take the initiative from Alexander in this topic.
I agree, I think the behavior should be the same as when double-clicking a cell.
I’ll forward this case to my colleagues. I will let you know when I get something.
