Spreadsheet API: ApiRange.Find is not a function
Do you want to: Report a bug
DocumentBuilder version: online demo / desktop 7.3.3.50 (inside a plugin, using callCommand )
Installation method:
OS: windows 10
Unable to execute example from the docs ONLYOFFICE Api Documentation - Find in the online demo ONLYOFFICE Api Documentation - Overview
Or use inside a plugin with
      var oSheet = Api.GetActiveSheet();
      var oRange = oSheet.GetRange("A1:AAA1000");
      var oSearchRange = oRange.Find(
        "EXAMPLE",
        "A1",
        "xlValues",
        "xlWhole",
        "xlByColumns",
        "xlNext",
        true
sdk-all.js:15863 TypeError: oRange.Find is not a function
at eval (eval at B (sdk-all.js:15863), :6:33)
at eval (eval at B (sdk-all.js:15863), :15:3)
Am I doing something wrong or is this a bug?
No longer an issue in desktop app, after updating to 7.4.0.163
Hello @arc-grigorenko
I’m glad to hear that the issue is not reproducible after the update.
Hi! Unfortunately, I had some more problems with this function.
I tried to search for multiple values in a specified range (E10:AAA1000) and coloring them, using ApiRange.Find() and ApiRange.FindNext()
  1. Only one cell being found in a column, with come columns resulting in no matches
  2. Cells outside of E10:AAA1000 being found
Code:
    window.Asc.plugin.callCommand(() => {
      var oRange = oSheet.GetRange("E10:AAA1000");
        "EXAMPLE",
        "E10",
        "xlValues",
        "xlPart",
        "xlByColumns",
        "xlNext",
        true
      oSearchRange.SetFillColor(Api.CreateColorFromRGB(255, 213, 191));
        I remember the cells Col and Row and stop the cycle after looping to previously
        visited cell,  but looping infinitely or in a for loop for a set amount of iterations
        results in the same behavior
      while (/*looping condition*/) {
        oSearchRange = oRange.FindNext(oSearchRange);
I also tried to search with ‘xlByRows’, which resulted in similar behavior, but one cell was being found per row instead of column
Sorry for the late response.
Could you please provide complete example of the code? In particular, what looping condition you have used to achieve the result on the screenshot.
I remember the cells I’ve visited and stop if I encounter an already visited cell:
      const functionCells = [];
      var didLoop = false;
        "EXAMPLE",
        "E10",
        "xlValues",
        "xlPart",
        "xlByColumns",
        "xlNext",
        true
      if (oSearchRange) {
        functionCells.push({
          Col: oSearchRange.Col,
          Row: oSearchRange.Row,
      while (!didLoop && oSearchRange) {
        const foundCell = {
        if (
          functionCells.some(
            (cell) => cell.Col === foundCell.Col && cell.Row === foundCell.Row
          didLoop = true;
        } else {
          functionCells.push(foundCell);
But using a simple for loop, with amount of iterations that larger, then amount of cells we’re trying to find results in the same behavior. If we log the cells while finding them, we’ll see that the findNext loops through the same cells infinitely. I don’t think the condition has anything to do with it
        "EXAMPLE",
        "E10",
        "xlValues",
        "xlPart",
        "xlByColumns",
        "xlNext",
        true
      for (let i = 0; i < 200; i++) {
Thank you for the code. We will take a closer look at it. I’ll let you know about the results.
