Dear all, a feature that I could not find so far and would be important for me is the split view of spreadsheets: in Excel, under the menu View, there is a “split” button that divides the spreadsheet in 4 Quadrants (2 horizontal +2 vertical parts), which can be scrolled independently. This is very helpful for editing large spreadsheets. Plain “freezing” is not as good, because then you can only scroll one part (the “non-frozen” one). Has anybody found any way to implement this “split view” for spreadsheets, maybe over some plugin or script or menu that I could not find? Thank you very much and kind regards
Hello, unfortunately, there is no such functionality for now. Thank you for your proposal, we will review it
Hello, I found out that there was a suggestion for relevant functionality earlier, I added your query to it.
