OS version: MacOS 10.14.6 (Mojave)
App version: 7.1
I have a big workbook: 1 worksheet has 7000 lines, 1 worksheet has 500.
Even in the 2nd one, if I insert a new line, or saving the workbook, takes a relatively long time.
Is there a way to speed this up?
Hello @Klaas-Vaak
I believe we have to take a closer look at your xlsx file. Is it possible to share it with us?
Hi Alexandre, thanks for reply so quickly
Unfortunately, I cannot share the file as it contains confidential info.
Isn’t there anyone in your office who has a big file?
We need the file where the issue is reproducible. We have big xlsx files, but I didn’t notice issues with them. I can assume that issue can relate to some formulas or data, but I need to check it out and reproduce the situation with your file.
Could you please hide sensitive data from file (or replace it with gibberish) > re-check that the issue still persists > provide us with the file. You can send it to me directly via PM
I am sorry, but hiding the data is too time-consuming. I will have to live with this then, such is life.
Thanks for your offer to help.
If you change your mind, you can contact me in PM.
I have been away for a bit and have now reinstalled OnlyOffice, version 7.4.1.
The 1st thing I noticed was that loading, and saving that same big file is a lot faster, while inserting a line is instantaneous.
So, the devs must have worked on this - kudos to them.
Thanks for your concern
This issue can be closed.
Thank you for your kind words. We are continuously working to improve our products.
Please feel free to contact us if you face any issues.
