In excel, you can snap objects (images,charts…) to grid by holding alt while moving or resizing. This is super useful. Is there anything like that in onlyoffice?
Hello @Toaster
You can snap objects in ONLYOFFICE Spreadsheet Editor. When you insert image an image, object ect. into the spreadsheet rightclick the object > Advanced settings > Cell Snapping > and select one of the options ( Move and size with cells, Move but don’t size with cells, Don’t move or size with cells). More information you can find in our Help Center.
This only makes them to move/size when adding/resizing cells. I want to perfectly align objects to cell borders.
Hello @Toaster
Thank you for the clarification! I will forward your suggestion to our Development Team for further consideration.
