Snap installation not work
I have a new VM (Ubuntu 22.04 LTS) by IONOS and have installed OO with Snap:
snap install onlyoffice-ds
No error occured.
If I set the command “snap list --all” I get this as output:
Name           Version        Rev    Tracking       Publisher    Notes
core20         20230503       1891   latest/stable  canonical✓   base,disabled
core20         20231123       2105   latest/stable  canonical✓   base
core22         20231123       1033   latest/stable  canonical✓   base
lxd            5.0.2-838e1b2  24322  5.0/stable/…   canonical✓   -
onlyoffice-ds  7.5.1          190    latest/stable  onlyoffice✓  -
snapd          2.59.2         19122  latest/stable  canonical✓   snapd,disabled
snapd          2.60.4         20290  latest/stable  canonical✓   snapd
If I now access to OnlyOffice with my URL https://onlyoffice.test.com there is only the normal index.html showing and not OnlyOffice!
Which steps did I forget?
Thanks and Regard!
Michael
Hello Michael,
If you see an index.html page when opening the address of your server in the browser, it means port 80 is already occupied by a web server. Please try installing the Docs snap package on a different port:
thank you.
I have first set to the port 8888
snap set onlyoffice-ds onlyoffice.ds-port=8888
and it works.
In my Plesk program I have installed for the Subdomain (onlyoffice.test.com) a let’s encript certificate. ( I need https to connect to nextcloud)
So I change the port from onlyoffice again from 8888 to 443
snap set onlyoffice-ds onlyoffice.ds-port=443
And it do not work.
Why?
Regards
Michael
You need to name the SSL certificate and key files as onlyoffice.crt and onlyoffice.key respectively, and then copy them to this directory:
cp onlyoffice.key /var/snap/onlyoffice-ds/current/var/www/onlyoffice/Data/certs/
cp onlyoffice.crt /var/snap/onlyoffice-ds/current/var/www/onlyoffice/Data/certs/
and run
snap restart onlyoffice-ds
as per the instruction: GitHub - ONLYOFFICE/snap-documentserver: The ONLYOFFICE Document Server snap package for the snap package system
