Hello, is it possible to expect that in the upcoming releases of the desktop version for MAC/PC platforms you will enable smooth scrolling in documents in the Document and Spreadsheet applications, as it is done in Numbers or Pages (Mac app)?
Now scrolling of the document in the Spreadsheet application occurs line by line, it is inconvenient if the row are expanded by 300 points to to get to the desired cell, need to zoom out the document or navigate through it with the keys.
Users are used to smoothness everywhere, in Pages and Numbers (on Mac) or even in browsers, it is very difficult for them to get used to the “jerky” movement of a document in Onlyoffice
If it is necessary to confirm with examples, I can try to send a recording from the screen for confirmation.
Sorry for the late reply.
We have this enhancement suggestion registered in our internal tracker under the number 18248. Currently, we are revisiting it, but, unfortunately, there is no estimated date when it will be implemented.
Apologies for the inconvenience caused.
In new version of Spreadsheet Editor scrolling is improved. Update for Desktop Editors will be available in a couple of days, please await for it and check the situation again.
Hi! I am new and really want to start using OnlyOffice over Microsoft products. While the app layout itself is nice enough, the scrolling is not smooth-feeling at all, and it feels like the letters are showing up slower than in word (as if the program runs at a lower framerate, I dont know). Are you planning on implementing a smoother document app in terms of scrolling and letter display?
