ShowWindow not working on view model
documentserver: docker 8.2.1.38
  "name": "发票管理",
  "guid": "asc.{019269E7-347D-7E4A-B7AE-15D6ED4A2280}",
  "variations": [
      "description": "发票管理",
      "url": "index.html",
      "icons": [
        "resources/light/icon.png",
        "resources/light/icon@2x.png"
      "EditorsSupport": [
        "cell"
      "type": "system",
      "isViewer": true,
      "isVisual": true,
      "isModal": false,
      "isInsideMode": false,
      "initDataType": "none",
      "initData": "",
      "isDisplayedInViewer": true,
      "events": [
        "onContextMenuShow",
        "onContextMenuClick",
        "onToolbarMenuClick"
code.js
function createNewWindow(name, title = '', size = [700, 400]) {
        if (newWindow) {
            Asc.plugin.executeMethod("CloseWindow", [newWindow.id])
        newWindow = new window.Asc.PluginWindow()
        const variation = {
            url: getFullUrl(name),
            isVisual: true,
            isModal: false,
            isViewer: false,
            EditorsSupport: ["cell"],
            buttons: [],
            description: title,
            isDisplayedInViewer: true,
            type:'window'
        newWindow.show(variation)
the new window working fine when editorConfig.mode = ‘edit’.
not showing the new window on editorConfig.mode = ‘view’.
the plugin zip is plugins.zip
Hello @langziyang
Please clarify how can I check the plugin is working properly. I see the sdk folder in the zip archive. Should I specify these files in the plugin config files? If you can record a video file with clarification, it would be appreciated.
@Alexandre
hi,the sdk just javascript file,like
and we still not finish the plugin,so if you can use it like:
https://www.sczqcgw.com/plugins/invoice/config.json
<script type="text/javascript" src="../sdk/jquery.min.js"></script>
<script type="text/javascript" src="../sdk/layui/layui.js"></script>
<script type="text/javascript" src="../sdk/plugins.js"></script>
<script type="text/javascript" src="../sdk/plugins-ui.js"></script>
 <link rel="stylesheet" href="../sdk/plugins.css">
the invoice is plugin,
Dear @langziyang ,
Please prepare the plugin with all dependencies and send it to us as single archive. So far, something seems to be going wrong during the deployment process via config.json.
@Alexandre
hi, this is plugin:
https://www.sczqcgw.com/invoice.zip
thanks
Thank you! We are checking the situation. I will update this thread as soon as possible.
Dear @langziyang
We have reviewed the situation and we added a bug to internal tracksystem. We have started working on it.
Thank you for the valuable data!
Hello, I am currently creating a window using the connector’s createWindow method:
let connectorWindow = connector.createWindow();
I’ve confirmed via debugging that the connectorWindow object is successfully created, but when I call the show method, nothing happens:
connectorWindow.show({
  type: "panelRight",
  description: "test",
  url: "./html/panelRight.html",
  icons: ["icon.png", "icon@2x.png"],
  isViewer: false,
  EditorsSupport: ["word", "cell"],
  initDataType: "none",
  initData: "",
  buttons: [],
Could this issue be due to the same cause as mentioned earlier?
Hello @peng
Are you opening the file in View mode as topicstarter reported?
I’m working in edit mode.
Thank you, we are checking the situation. I will contact you shortly.
