Show next Animation Step in Speaker View
Having the current status of the slide shown in speaker view is nice (if it works…). But it would be quite beneficial to see also a preview to the next animation step.
In total following slides should be visible:
  • Overview on all slides (where you should be able to zoom in - which is limited right now)
  • current slide
  • preview to next animation step (maybe as opt-in via check-box)
Hello @ProfMat
An interesting suggestion. I must ask - have you used such functionality in any other processor? If you have, then please share a link to the documentation about it for the reference.
Sure - that it why I’m missing such a feature. Imagine, you have talks or lessons from 8 am to 5 PM non stop - it is impossible to have all transitions in mind.
Here is a demo of your most probably main competitor:
They call it presenter view - which might be the better term.
If I remember correctly, they had a list of all slides at the bottom in an earlier version - which I personally preferred compared to the overview now hidden in a submenu. Maybe also this can be configurable (so either left, bottom oder submenu).
Thank you. We will take closer look at this documentation and then I will share the feedback.
I was informed that such suggestion was registered earlier, your query is added to it.
