I have originally posted these ideas in freeoffice forum but I decided to post it here as well in the hope that your dev team may decide to embrace the idea in the future as well. Both apps are great alternatives to Ms office.
Multi-grid sheets
Sheets should support more than one grid. Each grid should have its name and can support its own filtering, freeze and sorting operations . This is similar to mac numbers and rows.com . Grids could be resized to fit the table you are creating and when printing you can select which grid could be included in the print. Currently all spreadsheet apps follow the excel model, one endless grid that can be used unfortunately for only one table. The idea is that grids could complement each other in terms of information . One could grow endlessly while the other could provide analytics.
Bigger, more organized workbooks
This idea would complement the first one and it is that a workbook should be able to contain hundreds of sheets but they are not all loaded into the ram when you open the workbook, unless you designate a certain sheet to be loaded on startup. Instead it should load a sheet browser that functions like a file manager with each sheet having its own icon. You should be able to group them by letter or create groups and subgroups and direct your sheets to them . When you open a sheet , it is loaded into the ram and its tab is shown, but when all sheets are closed only the sheet browser is shown . This would allow a better ram consumption.
I understand all excel alternative want to to follow its model for compatibility. But this may limit originality.
Thanks a lot. Grids do not need to be movable like the case with mac numbers, rather listed above each other. As for the sheet browser, to achieve it I believe the plus sign next to sheet tabs would be replaced by an icon to the sheet browser, and sheet tabs would include close buttons.
Also you may have to introduce more relative cell reference, next to the current method of course , such as B first, B last , an B @row. Last in particular would be very useful for mult-grid design since users would continually add more rows to grids. For analytics in the second grid, for example, you will have to put something like : secondgrid.B4=sum(firstgrid.B3:firstgrid.B last) for calculating sum, and for average it would be : secondgrid.B6=average(firstgrid.B3:firstgrid.B last) , and so on.
Dear @shagi
Thank you for your suggestions.
We have added them to internal track system:
Add the ability to work with multiple sheets (grids) on one screen
Add the ability to create groups to organize sheets
Add a sheet browser\sheet manager
Unfortunately, I cannot provide you with any guarantees of implementation or ETA at the moment. There is still a lot of work and internal discussions ahead. However, I will keep this thread open and will notify you once we have something to share.
The sheet manager/ browser may have its difficulties . First each sheet would have its own action sequence meaning it should have its own undo and redo list in isolation with the other sheets ,unlike the current system that has one undo/redo list per workbook . Also creating cross-sheet formulas would be a challenge since all sheets are not leaded when you start a workbook. Consider a workbook as a containing folder with each sheet or page as a micro-file. A lot people may fairly argue against it since we already have file managers that can organize workbooks in folders and subfolders.
So please isolate this idea from the mult-grid idea . Failure for the sheet manager/browser to be implemented should not prevent the other idea from seeing the light . In it, I believe a sheet should be renamed a page. The multi-grid idea would bring plenty of benefits to users that are very hard to argue against and it is something that I have always wanted ever since I started using spreadsheets almost fifteen years ago. Converting from and to .xlsx format is something you will figure out, each grid, for example, would be converted to one full sheet and you can choose more than one grid to be converted as a workbook.
Thank you for your sharing. I can assure you that we are working on the implementation of these two ideas (multiple sheets (grids) on one screen and sheet browser\sheet manager) as separate, independent requests. The outcome of one of them shouldn’t affect the development of the other.
