Cloud 5 User version:
I can share a file with an external person so then can edit it via a link but the option to share a folder is not available as far as I can see.
Is this restricted?
Thanks
Is this restricted?
Thanks
Hello @linksgolfer
That’s right, you can share a folder with portal users only.
Thanks for responding Alexandre
Yes your right you can not share folders vai external link. However I figured a way around it.
Set up the folders you want to share and have external people edit on a different storage platform and integrate within Open office. I have used onedrive to set up shareable folders for external people and have the same folders in Open Office. This allows Sync between the two and works well.
Regards
Linksgolfer
