Set Focus to Cell
Hello everybody,
I’m currently working on a set of macos for worksheets. I set formulars to cells etc. But funnily I’m stuck with a quite simple problem (so it seems). After processing several cells, I’d like to set the focus (activate) a particular cell.
I tried something like:
oWorksheet.GetRange("B1:B1");
But that does not set the focus to the specified cell.
Can anybody help?
Hello @Dimpflmoser
Do you mean you’d like to select a cell or a range of cells? If yes, then for this Select method exists.
Hello Constantine,
I have already tried the select method - but nothing happens …
What my macro does is:
I first select cells from a row via GetRange and insert formulars to the cells. I then format the cells. So to the user it appears like a new input-row has been added, in which he can insert data which will be processed. What I’d like to achieve is that a certain cell in this row is activated - so the user can just start typing data into that cell. Let’s call the cell B2. But after processing the cells I use the select-method like follows (where intZeile represents the row number) the activated cell remains A2:
objRange = objTabbelle.GetRange("B" + intZeile);
objRange.Select();
Thanks again
You can use a separate object exclusively for the cell you want to select. For example:
// Initial process starts
var oRange = oWorksheet.GetRange("A1:D1");
oRange.SetValue("Processing");
// Process has ended
// Selecting a separate cell
var cellSelect = oWorksheet.GetRange("B2");
cellSelect.Select();
In this case after the data has been inserted according to your scenario, you can select exact cell with Select method. Isn’t that you are trying to achieve?
Hello, I’m also having an issue with focusing.
I have a large table where a row contains a period with dates spanning 3 months (e.g., 01/01/25, 02/01/25, and so on).
I want to write a macro that finds the current date, highlights the cell with that date, and scrolls (focuses) the table so I can see it.
Currently, I’m using Select(). The cell gets highlighted, but it’s outside the visible area of the window, so I can’t see where it is.
Hello @lusy
Do I understand correctly that in your case there is only one cell is returned? I mean the scenario where you are performing a search which supposedly should return a cell or several cells.
Hello @Constantine
The search should return only one cell, in my case, the one containing the current date.
I am using code that searches for the current date within a specified range.
Then, I use Select() to highlight the found cell.
The cell gets highlighted, but it is located outside my visible area, and the focus (scrolling) does not happen automatically.
As a result, I have to manually scroll and look for the highlighted cell on the right.
(function HighlightTodayCel() {
    try {
        console.log("Запуск макроса");
        var oWorksheet = Api.GetActiveSheet(); //записываем в переменную текущий лист
        //Переводим текущую дату в формат 01.янв
        var today = new Date();
        // Создаем массив с русскими сокращенными названиями месяцев
        var months = ["янв", "фев", "мар", "апр", "май", "июн", "июл", "авг", "сен", "окт", "ноя", "дек"];
        // Получаем день и месяц
        var day = today.getDate();
        var month = months[today.getMonth()]; // Получаем название месяца
        // Форматируем дату в формат "01.янв"
        var formattedDate = day + "." + month;
        console.log("Отформатированная дата:", formattedDate); // Вывод в консоль
        var oRange = oWorksheet.GetRange("C2:LQ2"); //Диапазон поиска
        var oSearchData = {
            What: formattedDate, //что ищем, переменнная текущей даты
            After: oWorksheet.GetRange("C2"), //Ячейка, после которой вы хотите начать поиск. Если этот аргумент не указан, поиск начинается после ячейки в верхнем левом углу диапазона.
            LookIn: "xlValues", //Тип данных для поиска (формулы или значения).
            LookAt: "xlWhole", //Указывает, будет ли соответствовать весь текст поиска или любая его часть.
            SearchOrder: "xlByRows", //Порядок поиска по диапазону — по строкам или по столбцам.
            SearchDirection: "xlNext", //Направление поиска диапазона - следующее или предыдущее совпадение.
            MatchCase: true //Учитывать регистр или нет. Значение по умолчанию - "false".
        var oSearchRange = oRange.Find(oSearchData);
        console.log("Результат oSearchRange", oSearchRange);
        if (oSearchRange) {
            console.log("Дата найдена в ячейке:", oSearchRange.GetAddress());
            // установить фокус
            oSearchRange.Select();   // Затем выделяем её
        } else {
            console.log("Дата не найдена.");
    } catch (e) {
            console.error("Ошибка выполнения макроса:", e);
Thanks for the sample, I see what the problem is. I’ll check out possible solutions, please await for my feedback.
Hello again @lusy
Unfortunately, there is no way to set a focus to specific cell. Based on that, we have registered an enhancement suggestion to make Select also focus on the cell. I will let you know once it is implemented.
Sorry for the inconvenience.
