Serious problems with token authentication
Ran into some token issues, first below is the process:
  1. get the onlyoffice service in docker again using the command
    docker run -i -t -d -p 8787:80 --restart=always -e JWT_ENABLED=false onlyoffice/documentserver:7.5.0 -dns 8.8.8.8
  2. Manually configure the token configuration file as follows:
    ① Enable token authentication for outgoing requests.
    ② Set the key for outgoing requests.
    ③ Set the transmission request in , inBody = false
The specific configuration is as follows:
“services”: {
“CoAuthoring”: {
“request-filtering-agent”: {
“allowPrivateIPAddress”: true,
“allowMetaIPAddress”: true
“sql”: {
“type”: “postgres”,
“dbHost”: “localhost”,
“dbPort”: “5432”,
“dbName”: “onlyoffice”,
“dbUser”: “onlyoffice”,
“dbPass”: “onlyoffice”
“token”: {
“enable”: {
“request”: {
“inbox”: false,
“outbox”: true
“browser”: false
“inbox”: {
“header”: “Authorization”,
“inBody”: false
“outbox”: {
“header”: “TOKEN”,
“inBody”: false
“secret”: {
“inbox”: {
“string”: “iaernYcofSqMfvseceUBQdS2jnh7RZZd”
“outbox”: {
“session”: {
“rabbitmq”: {
“url”: “amqp://guest:guest@localhost”
“storage”: {
“fs”: {
“secretString”: “EpFwrLvCKOUi1enaLl8j”
Based on the above configuration information, the following issues were encountered:
  1. when requesting “url”: “https://example.com/url-to-example-document.docx” file address, the header does not contain the token.
  2. when requesting “url”: “https://example.com/url-to-document-changes.zip” attachment address, the header does not contain the token.
  3. When requesting callbackUrl, the token is included in the header, but the token information also appears in the body, because the “inBody”: false I set should not appear in the body.
According to the document “ONLYOFFICE Api Documentation - Signature”, outgoing requests should all carry the token information in the header, but now problem 1 and problem 2 do not carry the token, how to solve this problem? ?
hey @Charles.yin :handshake:
Let’s clarify the following information:
  1. What do you mean by “token”?
    For information on JSON Web Token (JWT), you can refer to the following link: What is JWT
  2. Why did you set values using the JWT token?
Configuring JWT for ONLYOFFICE Docs: JWT Configuration
Enable token validation by changing the false value to true in three sections:
  • services.CoAuthoring.token.enable.browser
  • services.CoAuthoring.token.enable.request.inbox
  • services.CoAuthoring.token.enable.request.outbox
  1. How are you forming the token? “header”: “TOKEN”
  • services.CoAuthoring.token.inbox.header: Defines the HTTP header that will be used to send the incoming request token
  • services.CoAuthoring.token.outbox.header: Defines the HTTP header that will be used to send the outgoing request token
For token formation, you can refer to the following link: Token Formation
After configuring the above to true, the functionality is indeed normal, thank you very much for the discussion! This issue should be closed.
