Hi
os: windows 11
Onlyoffice desktop 8.0.1.31
the sequence fuction does not create any table only the first cell contains the first value of the sequence.
Hello, we are currently analysing the issue, I’ll inform you as soon as I have news.
Hello, for now this functionality works differently in our Editor. In order to achieve the desired result, you’d need to do the following:
- Select the range A1:B10
- In the formula bar enter =SEQUENCE(10;2;1;1)
- Press Ctrl + Shift + Enter on the keyboard
