During the compilation process, I encountered a failure to install the Google V8 engine. Does the new version of the compilation environment have any requirements for the base environment version, such as Python, GCC, etc.? In actual compilation, the V8 engine cannot be compiled based on Python 3.5, but the official website recommends using Ubuntu 16.04 system. The default version is only Python 3.5. Has the compilation tutorial been updated?
Hello @luoming
Please point me to the guide that you used for the compiling process and specify your OS. If it’s possible, please reproduce the situation and show us the issue itself, we will check it out.
Thank you for your reply, I have resolved the issue!
Hello @luoming
Well done! Please feel free to share your solution on the described situation, so other users can review it in case of similar issue.
