sorry, I write in my native language (translated with google)
desktop editor searches and tries to load libraries from several places, and the search in the current directory is performed earlier than in the traditional places where these libraries are located
for example, a piece of the strace log with loading the libgcc_s.so.1 library
openat(AT_FDCWD, "/opt/onlyoffice/desktopeditors/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/opt/onlyoffice/desktopeditors/converter/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/x86_64/x86_64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/x86_64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "tls/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "x86_64/x86_64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "x86_64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300-\0\0\0\0\0\0"..., 832) = 832
lseek(3, 92528, SEEK_SET) = 92528
read(3, "\4\0\0\0\20\0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0", 32) = 32
fstat(3, {st_mode=S_IFREG|0755, st_size=99688, ...}) = 0
mmap(NULL, 2192080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fe665268000
mprotect(0x7fe66527f000, 2093056, PROT_NONE) = 0
mmap(0x7fe66547e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7fe66547e000
close(3) = 0
The penultimate line of openat shows that onlyoffice tries to load libgcc_s.so.1 from the current directory, and then successfully picks it up from /lib64
An attacker can place his version of the libgcc_s.so.1 library (not only this one - the full list can be taken from the strace log) next to any document and get it loaded and executed with the rights of the user who opened the document.
for example, I copied the libgcc_s.so.1 library to the home directory of the test user and opened the document located there with onlyoffice.
strace output (partial):
openat(AT_FDCWD, "libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
getcwd("/home/test", 128) = 11
mmap(NULL, 2192080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7ff863223000
mprotect(0x7ff86323a000, 2093056, PROT_NONE) = 0
mmap(0x7ff863439000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7ff863439000
close(3) = 0
lsof output:
$ lsof +d ~
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pipewire 128360 test cwd DIR 8,3 4096 6688047 /home/test
dbus-brok 128397 test cwd DIR 8,3 4096 6688047 /home/test
dbus-brok 128398 test cwd DIR 8,3 4096 6688047 /home/test
pipewire- 128399 test cwd DIR 8,3 4096 6688047 /home/test
gvfsd 128451 test cwd DIR 8,3 4096 6688047 /home/test
bash 128566 test cwd DIR 8,3 4096 6688047 /home/test
DesktopEd 128828 test cwd DIR 8,3 4096 6688047 /home/test
DesktopEd 128828 test mem REG 8,3 99688 6688226 /home/test/libgcc_s.so.1
editors_h 128834 test cwd DIR 8,3 4096 6688047 /home/test
editors_h 128834 test mem REG 8,3 99688 6688226 /home/test/libgcc_s.so.1
editors_h 128844 test cwd DIR 8,3 4096 6688047 /home/test
editors_h 128844 test mem REG 8,3 99688 6688226 /home/test/libgcc_s.so.1
editors_h 128854 test cwd DIR 8,3 4096 6688047 /home/test
editors_h 128854 test mem REG 8,3 99688 6688226 /home/test/libgcc_s.so.1
editors_h 128856 test cwd DIR 8,3 4096 6688047 /home/test
editors_h 128856 test mem REG 8,3 99688 6688226 /home/test/libgcc_s.so.1
editors_h 128889 test cwd DIR 8,3 4096 6688047 /home/test
editors_h 128889 test mem REG 8,3 99688 6688226 /home/test/libgcc_s.so.1
lsof 128901 test cwd DIR 8,3 4096 6688047 /home/test
lsof 128902 test cwd DIR 8,3 4096 6688047 /home/test
