As far as I understand, it is not possible to search with regex at present. Is this feature scheduled, or should I try providing my own with a macro?
Many thanks for making this awesome software available to the community
Hi @pankus,
Regex are supported, here’s the list of available operators:
Thank you very much,
but I cannot find any reference in the documentation. Am I doing something wrong?
Also, although these operators are certainly helpful, these are not standard regexes.
To your knowledge, does onlyoffice only support these?
ALSO, while this list of wildcards is useful, a list of operators is needed as well as details on what variation of the named capture groups syntax is used. If I can’t refer to capture groups, it’s not really RegEx, is it?
In conclusion, this fundamental function for anyone working with data should be better documented and, if necessary, implemented in the program. Thank you
