Search function doesn't work on mobile
I installed the Android app (5.2.1 build 307 SDK 6.4.1.45) on my Pixel 4a 5g.
I have connected an Infomaniak kDrive account.
When i search a file, i always have the message “Nothing was found”.
Thanks for your help.
JF from France
Hello Jieffe.
We know about this issue and we are working on it (internal bug number - 52652).
The current search logic looks for a file in the directory where you are currently located. Therefore, if you go to the folder where the file is located, the search will work correctly. We are working on implementing search in all folders and subfolders. But I cannot provide you with timeframes at the moment.
Thanks Alexandre,
Even if the file is located on the folder, nothing works.
JF
are you in the same folder before starting your search? in this case, the search should work correctly. Please reproduce the issue and make a videofile.
Hi Alexandre,
I recorded my phone screen : SwissTransfer.com - Envoi sécurisé et gratuit de gros fichiers
JF
Hello @Jieffe
Is it possible to provide us with test account? So we are able to check it out on the spot. If so, please contact me via PM.
Hi!
With the last update (5.3.0 build 342 SDK 7.0.0.127), the search function works only in the folder where i am located.
It will be nice if it works everywhere!
JF
Hello @Jieffe
If it’s possible, please provide us with a test account (you can contact me via PM to secure sensitive information). We tried to reproduce the issue, but I think that we need an account where the situation is reproducible.
My drive contains important files, I do not want to do this test. This bug seems to be known to OnlyOffice, I prefer to wait. Thank you.
Ok, we are continuing investigation on our side. If we get any news, I’ll update this post.
Also I want to say thank you for pointing us to this situation.
Hi!
Two years later, this problem isn’t fixed.
Hello @Jieffe
Mentioned by my colleague issue was fixed in version 7.2 of Mobile apps. Please specify what version of Mobile app you are currently using and if you are still connected to any cloud solution when performing the search.
Hi !
I use 8.0.1 version, build 533, SDK 8.0.1.44.
The problem occurs with my kDrive.
Pixel 7 Android 14.
Thank you for sharing information. I have found out that the issue with search in Bolie app when connected to a cloud cannot be fixed due to WebDav connection limitation - it does not allow search throughout whole catalog. Currently search is only possible in the directory where user is located but it cannot be performed outside this directory.
As for the mentioned fixed bug: it was a bug with search within local files on the device outside the directory where user is in.
Ok, I unterstand.
Thanks.
