I am using seafile to integrate onlyoffice, but I found an error, this error is because seafile wants to access http://domain:port/cache/files/7ce5cf2b834907651929_559/output.docx/output.docx, and then found that it cannot be accessed , http status code 410, but onlyoffice can be used to edit and save files normally。This error also caused seafile to fail to generate a new key, modify the file version has changed, the page will be reloaded
Hello @zgydkf
Please specify version of all components: Document Server, Seafile and the connector app.
Additionally, please specify the guide that you’ve followed to configure connector app and installation type of Document Server (DEB/RPM, Docker, exe).
