Scroll "flickering" when collaborate on Docs
Do you want to: report a bug
Document Server version: 7.2
Type of installation of the Document Server
OS: Docker on Ubuntu, integration in Nextcloud
Browser version: Firefox 104
Hi,
When I use the Document Server to collaborate on a docx, (2 people in collaboration) the document window scroll alone to make the document match the middle of the page (c.f. the gif bellow).
Steps to reproduce:
  • Open a document with another person
  • One of the person is on page 1, the second on page 2
  • While the first is writing, the document of the second scrolls by itself to be on the middle of the page 2.
  • If already on the middle of the page no problem.
I was using Docs in integration with Nextcloud AIO there was the problem so now I’m using it with the docker deployement. And, with default configuration the problem is present.
Can you help me ?
Best Regards,
mdslam
firefox_AnnYMYvPLd
Hello @mdslam
We are aware of this behavior and we have this issue registered in our internal bug tracker under the number 59647. This bug will be fixed in the upcoming hotfix 7.2.2.
Sorry for the inconvenience.
Hello @mdslam
Recently we have released the version 7.2.2 of our editors.
Please update your instance of Document Server to the newer version and check the situation.
Hi,
Thanks for your answer, i’ll check with my collaborators ASAP.
I’ll get back to you.
