After editing the file and try to save it advertises that the file allready exists, and asks if I want to overwrite. I answer yes, and it looks like it’s beeing saved but it’s not.
Also I tryed saving the file on the computer and after that copying it into the folder in Synology drive. It will do the same. Ask if I want to overwright. I say yes, but it doesn’t do it.
The only way it works is if I change the file’s name.
We haven’t tested such a scenario with Synology Drive before.
We’ll try to investigate this situation. However, we need information about which protocol is used for file transfer and video playback to diagnose the issue*.
*Please record a video demonstrating the issue and provide it for further analysis.
Could you please clarify whether this issue persists when using file synchronization between your computer and Synology Drive?
