Document Server version: 7.4.1 apple silicon and apple X64
Type of installation of the Document Server (docker, deb/rpm, exe): desktop.dmg (apple chip)
OS: mac OS Ventura 13.5
Browser version: Safari 16.6
In old ONLYOFFICES there was the possibility to save documents as WORD files or just save the documents under a new name. Since version 7.4 the “save as”-Menu does not work.
Please fix that.
Thank you from Germany
I can see that you have sent a message on forum mail. I’d ask you to upload your video to any cloud storage and share it here as an external link. If you are aware of any sensitive data in the demo, you can send the link to me via PM.
Unfortunately, we didn’t manage to reproduce the issue with given description.
Can you record a video demonstration of the issue? Or at least more details for better understanding.
Hello Constantine, please open a document and try to save it as “Save as”. No dialog - with the choices to choose the kind of document - will appear. This is only new since Version 7.4
Hello Constantine,
i found the problem:
When using the file-menu in OnlyOffice, “save as” works fine!
When using the file-menu from the apple menu above, “save as” does not work!
