Running example script creates invalid docx-file that cannot be opened
DocumentBuilder version: recent
Installation method: windows setup
OS: windows 10
Hi,
I am trying out onlyoffice document builder. Right now I am trying to get the examples to run locally. I have followed the getting started instructions here and downloaded the setup for windows and run it successfully.
However the create document example ONLYOFFICE Api Documentation - Structure of a text document (and other examples as well) don’t work as expected. I have used the script in the example and run it locally on my pc. The script runs fine but when I try to open the generated docx file I get a warning about unreadable content in the file and it doesn’t open.
Actually I can run a script which generates a valid docx file here: ONLYOFFICE Api Documentation - Overview but can’t generate a valid docx file if I run the exact same script locally. I have tried running it in windows powershell as an admin and it didn’t change anything.
There appear two warnings. The first says “Word has found unreadable content” [would you like to proceed yes/no/] and after that another warning dialog appears which lists: Error when opening in word. Check file rights for the document / drive. Ensure there is enough ram provided. open with the restore converter.
THere is enough ram provided and I have write rights in the drive/folder.
Please help I am confused what I may be doing wrong.
When I tell word to recover any corrupted file and open the file generated by documentbuilder this way it shows me this:
customXml/item1.xmlEÁ
9Ç^J6;zÍMˆH5[Cò:W›6YBZb
customXml/_rels/item1.xml.relsÏÁjÃ0
W1º/Nv(e
%…]£$¦±e,u,o_
S
customXml/item1.xmlPK
customXml/_rels/item1.xml.relsPK
The file has been generated by running the Change the text font family example: Set font family for part of text or single word (text documents)
Hi, I’m not sure if this is a bug or a lack of permissions, but please try to save the file not in the builder directory, but to some directory like in our sample scripts:
builder.SaveFile("docx", "./TESTFILES/sample1.docx");
This way the files are generated correctly, the issue is reproduced only when saving directly to C:\ONLYOFFICE\DocumentBuilder
We added a bug regarding this issue to our internal tracker. Bug number is 53609.
