Do you want to: Report a bug.
When trying to sort a file with 50 thousand lines, the program crashes (Something went wrong…).
Sorting through the standard sorting functionality. Is there any way to bypass the memory limit?
Onlyoffice version: 8.1.0.169 (x64 exe).
Additional information:
There is 1 sheet in the file, 50 thousand lines are filled in. Columns from “A” to “BY” are filled in.
Hey @Rinzler !
Thank you for bringing this issue to the forum!
We would greatly appreciate it if you could provide the file in question, as long as it doesn’t contain sensitive information, or if you can anonymize the content (e.g., by replacing all text with placeholder characters).
Could you share the file that is causing this issue? We need it to reproduce the problem and identify the cause of the editor’s behavior.
Hey, @Nikolas!
Tried it on a file with 30 thousand lines.
Sort in descending order and after sort in ascending order.
https://file.io/MMkpeGbMB5NA
Maybe in Api there is a way to clear the history of changes (for example, call from a plugin or macro).
Hello @Rinzler
Could you please provide the specifications of your system, including:
- CPU
- RAM
- HDD
- OS (32-bit/64-bit)
Unfortunately, on my system, running ONLYOFFICE Desktop 8.1.1.27 (x64 exe), I don’t encounter the “Something went wrong…" error. The filtering works correctly for me.
