Hello, I have a question about reports to the center and projects. Does the product have the ability to create your own report on possible transactions or projects, not only those that are proposed. For example, I would like to use a report to display a list of contacts in a project and deal
Community Server/Control Panel version:12.5.1228/3.5.421
Type of installation of Workspace (docker, deb/rpm, exe)
OS:Windows Server
Browser version:
hi @makxkr
Reports can be generated only those that are in the suggested ones…
Thank you!
