in the full example configuration (http://DOCSERVER/web-apps/apps/api/documents/api.js) are layout options (see code example below) that should hide menu tabs. I have not found them in the docs and they have no effect on the editor on my test server.
Are these old or future options or am I doing something wrong? Other changes have effects on the editor.
Thanks in advance
Christian Rommelfanger
config = {
editorConfig:
customization: {
layout: { // hide elements, but don't disable feature
toolbar: {
file: false,
home: false,
layout: false,
references: true,
