Hello.
I have installed the software following this guide:
Installing server version using the provided script - ONLYOFFICE
Everything is fine, but when I embed the editor in my own angular app, using the ngx-onlyoffice component, I get the following error message:
Refused to display in a frame because it set X-Frame-Options to sameorigin
If I install the “Ignore X-Frame headers” chrome extension everything works fine.
Hello @jpalvaradomil
By default you cannot use Document Server that is a part of ONLYOFFICE Workspace with other applications. “X-FRAME-OPTIONS” is a result of trying to do so.
If you want to integrate your app with our editors please consider installing a separate instance of ONLYOFFICE Docs to your server.
For example, you can use Free Community Edition of ONLYOFFICE Docs:
https://helpcenter.onlyoffice.com/installation/docs-community-index.aspx
