Question
Hi, I’ve just started using onlyoffice docx and like it very much. I have just hit a simple problem. I renamed a file and pressed delete with a fat finger. I assume that file is in the trash bin, BUT I’m on an iPad and can’t find trash. I looked in files everywhere including Recently Deleted. So where is it please and do you have a trash icon?
Hello @Stumphole
Sorry for the late reply.
Did you work with file locally? Or did you connect the app to a cloud? For local actions (on the device), there’s a Trash folder where files are located once they were deleted.
Please clarify the situation.
