Hi all
When I paste some slides with images from one pptx (on my hard drive) to another (ditto), here is what I get:
Thanks !
Hi all
Thanks !
Hello @arcqus
Unfortunately, I wasn’t able to reproduce the issue with given description.
Is it possible to create a test presentation to share with us and provide a step-by-step scenario on how to reproduce the issue?
Hello @Constantine
Digging some old stuffs here
How to reproduce :
Expected result : the copied slide should contain the text and pictures
Actual result : the copied slide contains only the text.
I tested it in LO, it is working.
Thanks for analysing this.
Hello
Reading other old threads, I assume that this is related to this
I can confirm that it is the same issue as in mentioned thread. Since it was already registered based on your query, please await updates in mentioned thread.
